Re: Lenthening SC WFE.
Posted by Hugh MacKay on August 01, 2007 at 17:30:52 from (209.226.106.143):
In Reply to: Lenthening SC WFE. posted by Keith-OR on July 31, 2007 at 20:57:21:
Keith: I wouldn't advocate the porta power as the complete answer for every front end. I have seen porta powers snap the spindles and spindle housings right off the front end tube. If they are stuck solid enough, big tourches are the only answer. We just don't want folks thinking that is the ultimate answer. It's fine for the front ends that come apart reasonably easy. My advice to anyone using a porta power, once it's in there tight, make sure the tube moves an amount equal to the porta power every stroke.
I've seen several center tubes crimson before the adjustable tubes let go. Those tubes that were heated crimson 20 years ago are still on tractors and I know one of them has a loader. Without heat, I've seen a few front ends go to the scrap heap.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
