Re: 1486 IH
Posted by the tractor vet on August 01, 2007 at 19:30:32 from (75.19.125.194):
In Reply to: 1486 IH posted by Delilah on August 01, 2007 at 17:22:58:
Don't know as i did not do the job , are you sure that ya got all the O/rings installed on the tubes and did not cut one while you were pushen them in . DId you have the MCV apart ?? Did ya get the end clearance set correctly , Is the seletor valve working and set correctly ??? Did the cable come off ??? With out me being there there are a lot of did ya do this or that. Did ya check pressures and did ya install a new MCv pump???? Sometimes this falls under the heading that don't try this at home let the trained perfessionals do it .
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
