Re: Re: Farmall 300 hyd. pump seal kit
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Fudd@Work on February 11, 2000 at 19:23:23 from (205.242.73.10):
In Reply to: Re: Farmall 300 hyd. pump seal kit posted by Les Repair on February 11, 2000 at 18:02:33:
I put a seal in the pump on my 400 but it leaked again because the shaft was worn. You have to carefully remove the seal and get the number for a replacement or take it to a seal dealer so he can match it up. Good luck.
Post A Followup
: Re: Re: Re: Farmall 300 hyd. pump seal kit
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
