Re: Farmall ID
Posted by Danno on August 02, 2007 at 05:23:59 from (74.32.250.25):
In Reply to: Farmall ID posted by Danno on August 01, 2007 at 07:35:07:
Athol Carr said: Looks like an early F-20. There appears to be a model decal (unreadable) above the FARMALL decal. It has the geared steering not the worm steering box so it is a very early F-20. The regular had a side mounted exhaust whereas this tractor has a vertical exhaust, again F-20. The Regular would not have had an oil filter before 1929. The magneto appears to be an E4A (with cover) while most F-20s from 1934 on would have had the later steering and an F-4 magneto
So, i'm reading that the F-20 came out in 1932, so that would make it a 32-33 if the 34 on had the f-4 magneto?
Didn't expect to be able to narrow it down so much just based on a 70 year old picture!
