Re: Hand Crank, Farmall C, others?
Posted by georgeky on August 02, 2007 at 17:39:26 from (64.12.117.137):
In Reply to: Hand Crank, Farmall C, others? posted by Rock_Picker(MO) on August 02, 2007 at 17:23:51:
One from a C with 17 inch crank will work on nearly all others. The same is not true the other way as the A/SA/100/130/140 are a bit shorter than the one for a C/SC/200/230/ A/SA is 13 1/2 inches to the bend, B is 13 inches, Late SA with 123 engine uses a 16 1/2 inch crank. The Cub crank is also different.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
