Re: Generator on 1951 C Farmall
Posted by John T on August 03, 2007 at 04:51:32 from (66.244.83.147):
In Reply to: Generator on 1951 C Farmall posted by Greg2007 on August 02, 2007 at 19:36:02:
Greg, Heres a couple ways to tell which post is which if they arent labeled ARM and FLD as some are:
1) If the Gennys connection posts are different sizes, the larger is the Armature and the smaller is the Field.
2) If you remove any wires/leads to either post and use a decent ohm meter on the R x 1 scale, attach one lead to a clean metal portion of the case/frame, and whichever genny post has the most resistance to case is the Field and the other one the Armature. The resistance on the Field post (maybe 4 to 7 ohms vicinity) should be 3 to 6 ohms more then the Armature post to case/frame cuz it has the added resistance of the Field windings in series with the armature which leads to case/frame via the grounded brush.
Polarize the genny before you start her up.
John T
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
