Re: Hand Crank, Farmall C, others?
Posted by Rock_Picker(MO) on August 03, 2007 at 06:20:26 from (198.209.170.10):
In Reply to: Hand Crank, Farmall C, others? posted by Rock_Picker(MO) on August 02, 2007 at 17:23:51:
My crank is the 17 inch one. The pin is 3/8" diameter, 1_9/16" long, and 3/4" from the end of the crank to the center of the pin. The pin is horizontal if the crank handle is hanging down. Thanks to all for the info.............it helps.......NOW IF I COULD ONLY REMEMBER WHERE I GOT THE CRANK........Oh Well!..........RP
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
