Re: M top plate and leaking axle.
Posted by MN Scott on August 03, 2007 at 19:18:58 from (206.9.216.47):
In Reply to: M top plate and leaking axle. posted by Carden on August 03, 2007 at 17:46:30:
The M only has the outer seal to replace. There is no inner seal. Just take your wheel off and polish the rust and paint off the axle and slip the seal holder off the end of the axle. Install a new felt and seal and bolter back together.
