Re: Old super C
Posted by Handyman on August 03, 2007 at 20:27:43 from (63.239.240.1):
In Reply to: Old super C posted by DannyTN on August 03, 2007 at 19:41:12:
pull the head and and find out why the valve is stuck, (rusted,bent,burnt,etc). while you have head off check cylinder bores for rust and apply oil to cylinder walls to lube them up a bit. new plugs, points, roter and cap and it should be good to go unless there is something serious wrong like cracked head or such
