Re: Farmall B alternator
Posted by Janicholson on August 04, 2007 at 08:13:43 from (71.87.39.51):
In Reply to: Re: Farmall B alternator posted by Janicholson on August 04, 2007 at 08:07:48:
I just thaougt of another possible solution. Take the 14 ga wire with the diode in it and connect it to the coil at the positive terminal. That would allow the system to work correctly, and save wire in the box. (you stated that the coil has no ballast resistor and needs none if I remember correctly) If it has a Ballast resistor this wire I am discussing goes on the key side, not the coil side of that resistor. JimN
