Re: Anyone know of fix for a bad 5th in an M?
Posted by Bob Kerr on August 04, 2007 at 18:00:54 from (205.188.116.73):
In Reply to: Anyone know of fix for a bad 5th in an M? posted by dej(jed) on August 03, 2007 at 12:10:52:
My educated guess would be wore out bearings on the trans input shaft and possibly on the roller pilot bearing on the sliding shaft. If those all are worn out, they will let the shaft wobble and then it will spit the gear off. 5th gear is direct drive from the input shaft and the 4th gear has the teeth for 5th in the front center right next to the splines on the sliding shaft. if it gets off center it will tend to push the gear off. If something is bent in there, REPLACE IT! It will take a huge bar and a portapowerto put enough force on it to bend a shaft back and then it will still be off and also damage the other bearings holding it. The front trans shaft bearings can be reached through the belly pump opening and you may not have to remove the top plate.
