Re: My fascination with the Mag
Posted by CNKS on August 05, 2007 at 18:03:21 from (204.249.178.32):
In Reply to: My fascination with the Mag posted by Mike CA on August 05, 2007 at 00:00:39:
To me the answer is simple. If it has a mag that works, leave it alone. If it has a distributer that works, leave it alone. AND, one thing that is seldom mentioned--You can start a distributer equipped tractor with a crank when the battery does not have enough juice to turn the engine over. Note that I did not say "dead" battery. Most or much of the charge in a battery goes to turn the engine over. If it is low on charge it uses all the current to to turn over the engine, thus no spark gets to the plugs. If you crank it, the battery will often have enough charge to start the tractor.
