Re: Voltage regulator question on H
Posted by Bob M on August 05, 2007 at 19:38:52 from (69.205.124.61):
In Reply to: Voltage regulator question on H posted by Bob Kerr on August 05, 2007 at 07:33:54:
If the battery is good the charge rate should taper off to 3 - 5 amps or so as the battery approaches full charge. However as noted below, if the battery has about reached the end of it's life it may indeed charge hard and sweat around the caps even though it is fully charged.
Try taking a voltage reading voltmeter across the battery terminals after the engine's run at speed for several minutes. If it shows greater than about 7.4 volts the battery is being overcharged. I'd then be looking for a bad voltage regulator. If the voltage is lower expect the battery to give out before long.
Note: If you use a voltmeter use an analog VOM or a GOOD, industrial-grade DVM (like a Fluke...). Reason: Many cheaper DVM's give false readings on old tractor electrical on account of all the transients and "noise" flying around in these systems!
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
