Re: Farmall Super A engine problems
Posted by Daniel H. on August 06, 2007 at 09:24:39 from (66.226.34.159):
In Reply to: Farmall Super A engine problems posted by Danny Mac on August 05, 2007 at 15:01:40:
If it runs on after shutdown, I would check the timing. If the timing is off it will be weak and may be running hot. A check of the governor linkage as mentioned before should also be made. All of this is covered in the OWNERS Manual. That is the first book you need, as it has a complete maintenance section. I would check with Binder Books for a good reprint of the manual.
