Re: My fascination with the Mag
Posted by Janicholson on August 06, 2007 at 11:31:32 from (66.173.50.110):
In Reply to: Re: My fascination with the Mag posted by Randy as in Randy-IA on August 05, 2007 at 10:22:53:
The amount is relatively low. If 10 turns of 20 gauge enameled wire are wound around a good spark plug wire (even solid core) the output of that induction is about 80 volts, (enough to light a NE2 neon lamp), but not to crossfire. Putting that fine wire on a suspected wire from a bad cap can show up the fault. JimN
