Re: went to go look at this tractor
Posted by Pat-CT on August 06, 2007 at 18:01:19 from (68.9.234.208):
In Reply to: went to go look at this tractor posted by Pat-CT on August 06, 2007 at 17:23:32:
thanks you did answer it .. it looks stock tho no modifications that i could see also it had verry large tires on the back im 6'2 and they came up above my shoulder which is also weird because the tractor rode level its a verry clean instilation if it was done by the owner
