Re: weak magneto
Posted by El Toro on August 07, 2007 at 05:22:40 from (205.188.116.73):
In Reply to: weak magneto posted by dlp on August 07, 2007 at 04:32:13:
Pull the coil wire from the cap and hold it near a good ground to see if you have a hot blue spark.
I wouldn't spin the crank since it can injure you.
You may have a weak coil or it could be weak magnets that have lost some of their magnetism. The magnets create the hot spark when they pass by the coil. I would try new points and condenser to see if that helps. Hal
