Re: h rocker arm ratio
Posted by Bob Kerr on August 07, 2007 at 10:25:12 from (205.188.116.73):
In Reply to: h rocker arm ratio posted by akb on August 07, 2007 at 09:51:33:
You can check it by measuring from the center of the rocker shaft hole to both the valve end and pushrod end where they contact. If the same length both ways the ratio is 1-1. Sounds like you are building a hotrod. Increasing the ratio gets you more lift on the valve.
