Re: weak magneto
Posted by John M on August 07, 2007 at 14:29:22 from (209.213.22.170):
In Reply to: weak magneto posted by dlp on August 07, 2007 at 04:32:13:
Your mag is not, or should not be, like the one pictured below. Your magnet should be a horseshoe shaped magnet on the outside of the mag.Pull it off and see if it will stick to the side of the tractor and hold there, if not you have a weak magnet and will cause your problem. If it will stick, then points and condensor first. then if you still have the problem, then you need a new coil. If all that fails, then you have other problems. Email me and Ill tell you how to remagnitize the magnet.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
