Re: How do you adjust the seat tension?
Posted by PatMz on August 08, 2007 at 08:52:31 from (64.25.14.124):
In Reply to: How do you adjust the seat tension? posted by Mike CA on August 07, 2007 at 23:35:39:
JimN is on the right track here. It's working as a second class lever, the resistance (spring compressing) is being moved by the effort (you in the seat), and the fulcrum is at the front of the mounting bracket. Moving the resistance closer to the effort will reduce the mechanical advantage.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
