Re: IH 656 valve adjustment problems
Posted by teddy52food on August 08, 2007 at 10:11:37 from (204.73.107.177):
In Reply to: Re: IH 656 valve adjustment problems posted by Deamer1 on August 08, 2007 at 09:17:58:
Put the gauge on the worn part. That is where it will be when running. If you get it on the high spot they will be noisy. I set the valves with each piston on tdc. Runnlng mates are 1&6 , 2&5, 3&4. When you are setting #1, #6 will be between ex & in. Then turn it enough so #2 is between ex & in and set #5. Do this with all in the firing order which is 1 5 3 6 2 4. I would pull the rockers and clean up the tips on my valve grinding machine.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
