Re: M engine - How would you build it?
Posted by CenTexFarmall on August 08, 2007 at 10:21:35 from (172.165.242.6):
In Reply to: Re: M engine - How would you build it? posted by the tractor vet on August 08, 2007 at 08:54:46:
tractor vet,
How much quench clearance are you building in these engines? Also, what all kind of head gaskets are available? Can you get steel shim and composition or is there just one kind? What compressed thickness do you get out them?
I was also going to post and see if anyone has any been using the ULSD in the older diesels and if there were any consequences. I get the impression you've seen problems with it.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
