Re: M engine - How would you build it?
Posted by CenTexFarmall on August 08, 2007 at 10:42:07 from (172.165.242.6):
In Reply to: Re: M engine - How would you build it? posted by mark on August 08, 2007 at 09:37:10:
I tried to find out the same thing a few weeks ago but without much success.
I think you have to be a little more conservative with CR on a tractor vs. a car; the tractor spends a lot of time at or near WOT under a heavy load (plowing) compared to . Also with relatively large
cylinders and short cam timing, the dynamic CR ends up higher on a tractor. Prop plane engines actually have similarly convervative CR and if you think about it have a similar mission. They run low RPM at a high load and throttle setting. I haven't heard about "no lead" avgas, but it's been a few years since I drove one of those things.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
