Re: H on kerosine?
Posted by Janicholson on August 08, 2007 at 12:09:08 from (66.173.50.144):
In Reply to: H on kerosine? posted by Lanse on August 08, 2007 at 10:40:16:
There were (are on some) seperate tanks for gasoline and second fuel. When shutting it off, the maun fuel was shut off and the carb was drained. The starting procedure included turning on the gasoline from the small tank, and starting it on gas. then when warm (shutters over the radiator to block the air, and heat to the intake manifold with exhaust passing over the outside in a special manifold) then it was switched to the less volatile fuel, and operated. JimN
