F20 Heisler OD refresh
Posted by Scott in SC on August 08, 2007 at 15:10:43 from (205.188.116.73):
Just refreshed the Heisler OD on my 1936 F20. The input seal was leaking in a major way, and since I was going to go in there anyway I decided to replace the bearings as well. The seal was an ancient CR (Chicago Rawhide (real rawhide)) seal, and had rusted to the input seal surface. The sleeve the input seal surface rides on had corroded badly, and I could not locate a replacement. The bearing house representative said he had never seen anything quite like the input gear, bearing, and sleeve set-up the Heisler had. I had to work the sleeve over well and fill pits in the surface with JB weld. It worked out really well. If your sleeve is beyond recovery perhaps one of those thin and handy axel seal savers could be used. Be advised the sleeve is a press fit to the input shaft/gear. The following are the original bearing numbers and the replacement seal number. Running these past a good bearing house prior to disassembly will reduce the anxiety associated with refreshing your own unit as well as speed things up. You’ll also need to replace the 6 tiny (about .185) ball bearings that hold the sliding gear in high or low range. The bearing house easily fixed me up with replacements for these worn detent balls. Make sure you tighten the four mounting bolts inside the housing that hold the OD to the transmission as well as the two outside on top of the unit. Input bearing New Departure 5207; Countershaft bearings ND 3304 and ND 3204; Input seal (TCM brand) 16253TB-H. I ended up making new gaskets for it but the unit is free from leaks, is quiet, and works like new. Good luck, Scott in SC
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
