Re: M engine - How would you build it?
Posted by CenTexFarmall on August 08, 2007 at 19:56:54 from (172.136.167.244):
In Reply to: Re: M engine - How would you build it? posted by georgeky on August 08, 2007 at 19:20:10:
I've worked my '52 M pretty hard, toughest is pulling 3 bottoms through this black clay. It's just tired; a little blue smoke now and then and plenty of blow-by. The sheet metal is quite good though and I'm thinking about it for a restoration candidate. I'll keep it running while I build on of the other two.
I wouldn't be surprised if IH never did actually make the pistons themselves.
Do you happen to know what kind of rings you are using? I suspect the originals were chrome faced but I've seen adds for moly faced rings. I've had good luck with moly rings in auto applications. They don't like dirt though.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
