Re: Farmall 400 p/w steering? NO right p/w? internal help
Posted by SDE on August 09, 2007 at 08:30:37 from (69.179.7.226):
In Reply to: Re: Farmall 400 p/w steering? NO right p/w? internal help posted by t.r.y. on August 09, 2007 at 07:40:10:
If you type Behlen power steering in the search box, you will get about 345 hits. Last year I posted the address to a two man shop in ST Louis who can time your gears for you. It will cost $55 if you send them just the gears. I got the address from someone else's post. Their phone number is there also. I think his handle was "Zoey" and and he had put it somewhere in the left hand column.
I am going to have to do the same thing myself. I did the exact same thing and later I read in the manual that you need to mark the gears so that they came go back in exactly the same way. The P/S unit was off a tractor that had a cornpicker on it, so it must have worked prior to my disassembling it.
Good Luck
SDE
