User ip.
Posted by jonnny2006 on August 09, 2007 at 15:55:08 from (67.142.130.25):
I know that i.p's change with each fresh ping off a particular server. the odds of the same i.p. number coming up when the forum is dead and a few mins later the other handel has the same i.p. addy. now he should off logged off and then i would have no idea with out accessing server log on reports. they put the tag on there for a reason. My id changes with each new ping off the N.O.C. Enough said. all i was getting at is use the same habdle no matter what you have to say. All i meant by it was the same comouter is there could be two people using the same lap top having drinks together...that would explain the same i.p. so close in time. I'm off to th tractor pull. my fav drink is Gieasel.... gas diesel mix. more gas then diesel on the rocks.
