Re: Farmall B ignition
Posted by billde on August 10, 2007 at 18:00:10 from (72.26.87.225):
In Reply to: Farmall B ignition posted by Dave H (MI) on August 10, 2007 at 17:10:29:
If you are still 6 volt, do not jump start through the battery with a 12 volt vehicle. Jump start through the starter instead.
