Re: Can a 530 engine be put in a 1066?
Posted by K.B.-826 on August 10, 2007 at 18:28:29 from (68.115.104.106):
In Reply to: Can a 530 engine be put in a 1066? posted by Gary A Brown on August 10, 2007 at 17:48:51:
Either will work fine, since you've got the original engine to swap parts off of. You'll definetly need the front and rear engine plates off of the tractor engine, and you may need the oil pan, manifolds, and turbo as well. Your 414 could be built bigger, but I think I'd look for at least a C series block and get away from that A series.
