Re: What kind of tractor is this? (PICS)
Posted by deereabhm on August 10, 2007 at 19:00:48 from (71.79.45.224):
In Reply to: Re: What kind of tractor is this? (PICS) posted by Patrick Martin on August 10, 2007 at 17:35:28:
It is worth probably more than 500 in scrap metal. I would never do that to that tractor though. As the tractorvet says you could completely redo that tractor for at least $20,000. If you got it running even if it was pretty rough you could get a couple thousand out of it. A nice 1066 can go around 10,000.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
