F-30 head bolt repair
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by C.Fitz on February 13, 2000 at 06:13:04 from (146.145.106.13):
Broke a head bolt off on F-30 head at the water-manifold a year ago. I drilled it out and re-tapped it.Thought it was OK when I torqued dowm with new bolt. Found a small amount of anti-freeze leaking at the head gasket right at that same head bolt.That head bolt will not torque down and is now stripped. Pulled the head back off and am going to use a "Re-coil" kit to repair thread in head. Has anyone had success with this and where can I get correct head bolts? If I have to make the head bolt myself what type of bolt do I use for the head? Case hardened? Thanks.
Post A Followup
: Re: F-30 head bolt repair
