Re: c axle seals
Posted by georgeky on August 11, 2007 at 09:03:46 from (64.12.116.73):
In Reply to: Re: c axle seals posted by Hunter in al on August 11, 2007 at 06:27:46:
The bull gear is held on the axle by a big flat washer and bolts. The axle housing must be taken loose from the outside of tractor and then it will just pull out of the bull gear if that washer and bolt is removed from it. The bull gear itself will not slide off on the inside unless the pinion cage is removed, but you don't need to fool with it. Just unhook the bull and then take out all the axle housing bolts and pull it right off. It is heavy so don't drop it on your toe.
