Re: Question about fuel tank sealant
Posted by Patrick Martin on August 11, 2007 at 11:57:24 from (64.154.26.250):
In Reply to: Re: Question about fuel tank sealant posted by gene bender on August 11, 2007 at 10:26:46:
You should try to just drill it out. I assume it has a sediment bowl underneath correct? If so a good sharp bit should work.
JFYI some solvents and acids will remove the sealer. If you choose to remove the existing sealer and go with a new one then check into the stuff that POR-15 makes. I use it all of the time and it seals hard as a rock.
