Re: getting overhauled Cub engine to start
Posted by El Toro on August 11, 2007 at 16:45:55 from (205.188.116.73):
In Reply to: getting overhauled Cub engine to start posted by Farmallb on August 11, 2007 at 18:24:27:
Did you measure the ring gap on the new rings before installing them on the pistons? I would bring No1 piston to TDC on the compression stroke
and then look at the valves on No1 cylinder to see if both are closed. This will determine if the valve timing is off. Hal
