Re: Super A fuel problems
Posted by Pete7 on August 11, 2007 at 18:18:48 from (71.243.142.63):
In Reply to: Super A fuel problems posted by Muley on August 11, 2007 at 11:48:09:
When you disconnect the fuel line and get a good gas flow does the bubble go away? If so, then I'd also check and see it the carb float is either sticking closed or needs adjustment.If that float is stopping the flow of gas before the bowl is properly full your engine will run poorly and you could get that bubble problem in the sediment bowl.
Pete
