Re: How to tighten an M head?
Posted by Buzzman72 on August 12, 2007 at 10:54:56 from (74.129.208.5):
In Reply to: How to tighten an M head? posted by terryjd98 on August 12, 2007 at 10:09:29:
A good rule of thumb on torqueing head bolts is to start with a bolt closest to the center of the head and torque them in a circular/spiral pattern, ending with one of the outermost head bolts. Another rule of thumb is to torque the bolts in three steps...in other words, if the specified torque is 75 foot-pounds, torque ALL the bolts to 25, then torque all the bolts to 50, then torque all the bolts to 75. And after running the engine a few hours, and getting the engine well warmed up, it's a good idea to re-torque the bolts...again, in sequence. BTW...most Farmall M's I ever saw used studs and nus, rather than head bolts. Coolant won't turn your oil black...but dirt will. Coolant in the oil will make it look milky. Since you already removed the head, it won't help now...but a cylinder leakdown test would've told you whether the rings or the valves were at fault for low compression. With compressed air applied to a cylinder at TDC on the compression stroke--which would mean that the valves are also closed--hearing air leaking out the intake would indicate a bad intake valve; hearing air leaking out the exhaust would indicate a bad exhaust valve; and hearing air leaking into the crankcase would have indicated bad compression rings. A lack of compression could be the result of an intake valve not opening...perhaps from a bent or broken pushrod, or a bad rocker arm, as well as a leaking valve or ring problem. If your lack of compression coincided "suddenly" and directly with a valve adjustment, I'd suspect valves that weren't closing as a result of improper adjustment [too tight], rather than a "sudden" burned valve or a "sudden" failed compression ring. But then, long-distance diagnosis IS a very INexact science.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
