Re: Farmall B - timing the engine when...
Posted by Patrick Martin on August 12, 2007 at 16:55:20 from (64.154.26.250):
In Reply to: Re: Farmall B - timing the engine when... posted by Patrick Martin on August 12, 2007 at 16:41:34:
Hey Dave, I think all you need to do in this case is to remove the two distributor bolts and clamps, rotate the distributor where it is aligned center (cap clamps top and bottom), and pull it out and turn the rotor to wherever position you want it in.
Sorry bout the above, hope it didn't confuse you. I was thinking about something else.
