Re: milky engine oil
Posted by El Toro on August 13, 2007 at 15:01:09 from (205.188.116.73):
In Reply to: milky engine oil posted by scott taipale on August 13, 2007 at 13:54:23:
All those sparkplugs should be removed and the engine spun over to get rid of the water. It could be just rain water. I would squirt or pour some clean engine oil into each hole then crank over the engine to coat the cylinder walls.
Then add a little more oil. This keep the pistons from getting stuck. I would drain a little oil from the pan to see if has water. Hal
