Re: Super M amp gauge dance
Posted by John T on August 13, 2007 at 19:41:36 from (66.244.83.147):
In Reply to: Super M amp gauge dance posted by George T. on August 13, 2007 at 19:22:29:
I dont like an ammeter to jump n dance around either. Some possible causes are:
Worn brushes,,,,,,weak or stuck/corroded brush hold down spring assemblies,,,,,,,,worn genny commutator to the point the mica seperating segments arent sufficiently undercut making the brushes bounce,,,,,,,,,,,,burned/carboned VR contacts,,,,,,,loose ground or loose/corroded wiring connections,,,,,,,bad VR mount making a loose or intermittent ground..... LOTS MORE BUT THESE ARE TYPICAL CAUSES ID CHECK FIRST
John T
