Re: CHAD S I NEED HELP
Posted by Patrick Martin on August 14, 2007 at 01:38:46 from (64.154.26.250):
In Reply to: CHAD S I NEED HELP posted by noidea on August 13, 2007 at 19:19:57:
Are you sure your plugs are grounding????? Might check to see if there is any goo in there preventing a good ground. Easy way to check is to wrap a wire around the plug at its base so that upon final torque it pinches the wire. Run the other end to a definite ground or the negative side of the battery.
See what that does then let us know.
