Re: O. T. Sweet corn and coons
Posted by teddy52food on August 14, 2007 at 10:41:51 from (204.73.107.177):
In Reply to: Re: O. T. Sweet corn and coons posted by DennyF on August 14, 2007 at 09:59:14:
I run 3 wires about 5 or 6 inches apart. I ground the center wire so if the ground is too dry they get it when they get between the wires.
