Re: F-12 hard start?
Posted by Janicholson on August 14, 2007 at 13:34:04 from (71.87.39.51):
In Reply to: F-12 hard start? posted by Kurt Wentorf on August 14, 2007 at 13:10:58:
The impulse coupling may be sticking and not allowing the mag to hold back and spin fast through the start setting. If it starts with a bit of a roll, or pull, it is the most likely. Cranking by hand (in Neutral of course) there should be a easily heard click from the mag when the timing marks are just at or a bit past the pointer. If mot clicking, the mag needs to be marked for position,the tractor not moved, nor engine spun, and the mag removed to clean/degrease and relube the impulse coupling. JimN
