Re: Re: Re: Re: Re: Super A , magneto timing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Jim Becker on February 13, 2000 at 17:18:16 from (209.30.171.102):
In Reply to: Re: Re: Re: Re: Super A , magneto timing posted by Carl on February 13, 2000 at 13:51:12:
OK, I'll back up and start from the begining. First off, The timing gears in the engine need to be in time. Marks on the cam gear lined up with the crank gear, then the marks on the governor/magneto gear lined up with the cam gear. If they haven't been removed, they are probably OK. Then the internal gears of the magneto need to be lined up. There should be marks showing on these gears. In fact, there are 2 marks. One for clockwise rotation, one for counterclockwise. I think the double set of marks is only on one gear and you line the appropriate one up with the single mark on the other gear. I think the correct mark is a "C," although I suppose it could be an "R." Then to install the magneto: Turn the engine until it is coming up on compression on cylinder one and continue turning (much less than 1/2 revolution) until the 0 timing mark on the flywheel is at the pointer. Turn the magneto drive clockwise until the impulse clicks with the rotor pointing to the tower for cylinder 1. Maintaining the coupling in as close to this position as possible, install the magneto on the engine and rotate the top of the magneto towards the engine block. Crank the engine over 1 revolution, bringing the timing mark back to the pointer. Slowly rotate the magneto (top away from the block) JUST until the impulse clicks. Give the engine one full revolution and while turning it very slowly check to see that the impulse clicks just as the mark comes into alignment. Make especially sure that it doesn't trip before the mark reaches the pointer.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
