Posted by Bob M on August 14, 2007 at 18:59:59 from (69.205.124.61):
In Reply to: M Alternator belt. posted by Andy Schuppert on August 14, 2007 at 18:39:14:
Andy - I'm going from memory but recall the correct belt is an A33 (1/2" x 33"). Use this info at your own risk however(!)
If you have an old, A-section belt larger than about A36 you can quickly determine the correct size:
First swing the alternator in on it's adjustment as close to the engine as it will go. Now cut the old belt, wrap it around both the water pump and alternator sheaves and back onto itself. Mark the spot where the belt end overlaps. Then remove the belt, lay it out straight and measure from the belt end to the mark you just made.
The length in inches (rounded up to the next whole inch) will be the belt size you need.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
