Re: Question, Jim
Posted by Dave H (MI) on August 14, 2007 at 19:13:56 from (64.12.116.73):
In Reply to: Question, Jim posted by ScottyHOMEy on August 14, 2007 at 16:10:33:
Hey there, welcome back! Jim was kinda scarce over the weekend too but the substitute teachers were great guys and I worked thru a knotty distributor issue with their help. I combined your advice with a couple others....just can't see squinting at points to see when they open when I can just let the spark tell me (thanks, good tip!)....and just like that I had a running tractor again. Not clear if this linkage adjustment is going to improve my throttle arm movement any but I am going to give it a look tomorrow. Due to the amount of crud in the sediment bowl I am considering a carb rebuild on this tractor or at least a good cleaning. Confidence is high that I can get it back together and adjusted since this tractor actually has brakes and a load can be put to it. Have to think on it a bit cause I would really like to move on to the 2N but I also really want to leave this B knowing that I did a complete job and she can go to the field next month.
