Re: Re: Re: Is there a cam bushing on farmall a (c113) engine?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by medfarm on February 13, 2000 at 19:15:55 from (209.162.37.67):
In Reply to: Re: Re: Is there a cam bushing on farmall a (c113) engine? posted by Tom Owens on February 13, 2000 at 15:45:48:
According to the shop manual, the clearance between the cam shaft and engine bearing surface should be between 0.0015" to 0.0035". You could probably get by with 0.005". As your machine shop said, the more the clearance, the less the oil pressure. Good luck.
Post A Followup
: Re: Re: Re: Re: Is there a cam bushing on farmall a (c113) engine?
