Re: drawbars
Posted by Hugh MacKay on August 15, 2007 at 01:45:29 from (216.208.58.182):
In Reply to: drawbars posted by HENRY E NC on August 14, 2007 at 20:44:30:
Henry: I think that final drive, as it applies to the 3 bolt pattern for mounting implements and drawbars never changed from first A in 1939 right through to the last 140 in 1979. I have a SA, 130 and 140, a friend has an A and while I've never measured, I'm certain bolt pattern is the same. I know my three are. All you need do is measure the bolt pattern.
The final drive did change some around 1953-54, but it was nothing more than change in brakes and beefing up casting for fast hitch. On the outside of those final drives, I'd be awfully surprised if there are any differences.
