Jeff - As long as the dead battery does not have an internal short (ie. the battery charger does nothing when connected) simply jump the tractor the normal way. Once the engine starts keep the RPMs a little above idle - the generator will provide sufficient current to run the ignition even after the jumper cables are removed. (Of course if the tractor has a magneto it's run fine even at idle w/o the battery...)
If the battery IS shorted, disconnect the ungrounded battery cable and use a zip tie or similar to keep the ungrounded battery cable terminal from grounding on anything. Now connect your jumper cable to the ungrounded battery cable terminal and proceed as above.
IMPORTANT! Observe the tractor's ground polarity when jumping. Connect only + to + and - to -; even if the dead battery has been disconnected or removed!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
