Posted by Bob Kerr on August 15, 2007 at 07:09:01 from (64.12.116.73):
In Reply to: gear noise posted by deane ferrish on August 15, 2007 at 01:44:41:
Better check out the front transmission input shaft. bearings may be bad and have caused wear on the gears where it shouldn"t be. I replaced all the bearings in my H and I do get a little noise when pulling and it quiets when coasting. The noise on mine came from the input shaft to the constant mesh gear that drives the lower tranny shaft. There are a total of 3 bearings for the front input shaft. 2 ball bearings and one pilot roller bearing on the upper trans spline shaft. If it only makes noise when moving, even in neutral it may also be the ring and pinion. I do think they have a tendency to wear out that front input bearings since they are always turning when the clutch is out and the bearings are smaller compared to some of the other tranny bearings.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
